How to add now plating cover art to movies page?
Postby Russell on Wed Dec 22, 2004 1:08 am
What will be the easiest way to and the cover art for a now playing box in the movies screen. I have it for the music fine. but I want it for movies as well. So after you choose the movie and press play the overlay closes and the now plying box has the current cover art.
Russell
Postby Colby on Wed Dec 22, 2004 1:36 am
Russell it sounds like youre using a skin, ("close the overlay...") What skin are you using? I would recommend setting up a spider to find the movie coverart. Much like I did with my music spider. If you are using my skin I could easily do this if there is enough demand for it. Hope that helps.
Postby Russell on Wed Dec 22, 2004 4:32 am
Colby, it is your skin (modified a little).
I already have the cover artt. I just want to have a now showing preview box that will be on the screen from the moment I hit play until the movie is over.
Also do you know how to get Premovie manager to work with offline events. I have it OK for online.
Russell
