Hey defrag,
I've been trying to incorporate this plugin into my ZoneSkin project. For the most part it seems to be working, except...and this is big, it doesn't play ??? As a matter of fact, the -hidden database remains empty. I switch over to your test skin, and everything works great. I switch back, select any genre...all displays...find a station I want to play...which played in your test skin, go to play...nothing (the small winamp connection window does not open)? Question, did you somehow tie the -hidden database (or some associated code) to your test screen so it only runs with that?
To let you know, I copied your event list over to my skin, so I'm using your event commands for play (from 0 to 9), I have all the variables displayed fine. Everything appears to work, but the button event for playing does not work. I checked the -hidden database and it is empty (when using your skin, there is a .pls entry).
I'm a little confused and hoping you can straighten me out. Oh, and I have now tried this on two different computers...and the results are the same.
Thanks in advance.
