II can't get theatertek (2.1) to launch properly when a dvd (stored on hard disk) is clicked on. xlobby can find the movies ok, and tries to launch
theatertek, which launches but does not play the movie. It just sits there like
it doesn't recognize the movie you told it to launch - using theatertek's
"Open" dialog after it launches works fine.
Any ideas? I have tried a couple of different skins I downloaded, but have not customized xlobby in any way.
