I have a question about movies and buttons pertaining to them...
We have one TT running and one of the things that's annoying is when you play a movie and then you turn off your ppc or something.  When reconnecting if you go to "Play movie" again it will re-open theatertek.  I've gotten around this (kinda) with a button that will bring you straight to the ppc_movie_ctrls screen foregoing the starting of theatertek.  What I'd like though is when you hit the play button, if nothing is playing it will play the dvd, but if something is already playing then it will simply bring up the ppc_movie_ctrls.
My question is this:  Is there some sort of command line that would change where the button goes depending on TT?  Such as if theatertek is running or one of the things I thought of was something like IF nowplaying>0 or some crap like that.
This way also if someone was watching a movie, it wouldn't be interupted by somebody in another room trying to watch a different movie or something.  It would just say "movie already in progress" and bring it to movie controls.  Hopefully this works out pretty good.  If not I guess I'd be happy with a "now playing" for dvds that I'd put on the all movies page so you can tell if you should just go to controls or if you should start a movie.  Thanks, seeya.
Ben
 by bmblank on Sat Sep 30, 2006 11:01 pm
