by carlt7 on Sat Jan 31, 2009 2:40 am
I am using last free version of XL (2/28/07 exe.) I am using Cinematic Collection Viewer (Tom Gaines) to convert DVD Profiler 3.5 database and have followed directions for importing the converted info: I get the coverart and plot for all movies when importing; however, I am not able to play my “Online” movies from the external hard drive with 200 movies. The correct path for playing the movies is not correct if you go to “edit” movies database: all movie titles are checked “offline Item” and the parameter is video_ts (no path to the hard drive/movies.) If you import from Basic - “Media Paths” all movies on hard drive are imported with correct movie path and offline will be unchecked, movies will play, but no coverart or plots. QUESTION: How do you get coverart, plots, and the correct path to play the movies? I have tried everything possible from reading posts and have printed a ream of paper with answers. I hate to give up and use VMC with My Movies unless I can solve this problem. My son has the full blown XL system and it is awesome, but I can’t justify spending that much money to play movies. Any help or suggestion will be appreciated. (I posted this earlier in another section and it was suggested I repost. Thanks for your consideration
