Tyler Skin Error
Tyler Skin Error
Postby m_ski on Wed Dec 08, 2004 8:02 am
I am trying to use the Tyler Skin from the XlobbyFr site. I have a full installation from the french installer but when I run the tyler skin and restart xlobby it always stalls at 'Loading.. Images..' on the splash screen, with the error message ' Failed to load resources from resource file. Please check your setup'.
Can anybody help with this issue or point me in the right direction to try and find out what resources might be missing?
The Tyler skin can be found at http://forums.studio-biorythm.com/index ... c=303&st=0
m_ski
Postby C-moi on Wed Dec 08, 2004 10:08 am
do you have an error when you try another skin with the french pack ?
i have tried this skin and i have no problem with it : it's an old skin so the new plugins of the french xlobby team aren't used by this skin but you can add yourself (there is a little help on this forum : use the search button with these words :
xant, xmovewindow, xevent, xcam ...
C-moi
Postby m_ski on Wed Dec 08, 2004 12:21 pm
No, other skins work fine. I tried maTV and that works OK.
m_ski
Postby dgemily on Wed Dec 08, 2004 12:47 pm
I will keep an eye on it tonight, and I will try to tell what is wrong...
Later,
dgemily
