topic of airpanel users
Postby ingalls on Mon Dec 20, 2004 10:03 pm
Hello,
I just baught a airpanel, and I wanted to know you were using xlobby with it.
Do you use two computer with one master and one client or only one?
Wich skin do you use?
ingalls
Postby ingalls on Thu Jan 06, 2005 8:58 pm
up!! :oops:
ingalls
Postby hjackson on Fri Jan 07, 2005 6:52 am
Well the Airpanel is essentially just a monitor for one PC, so you would typically use it in a one PC system where it acts as a touchscreen moniter for the server. Things may have changed, but in the past, the Airpanel, would turn off the output to the "wired" monitor out of the PC. As a result, the Airpanel would be a bad choice if you wanted to watch a DVD movie through the server PC as you would see nothing on your main screen. You could get around this if you managed to get a dual monitor setup working or if your DVD player was external to your PC.
You would not normally use the Airpanel as a moniter for the client UNLESS for some reason your client was a big bulky PC and you wanted the portability of a smaller touchscreen. In this setup you COULD operate the Airpanel AND watch a DVD from the server PC on your main screen.
I personally use a small touchscreen PC (ProGear) as my clients so I don't need a second small touchscreen remote to control the first small touchscreen remote. I have considered the Airpanel for some other server PCs I have where I do not use them for HTPC DVD use (ie. my music server)
Later!
hjackson
hjackson
