"Home" Key - How to Disable Xlobby minimization???
Postby smarty on Mon Dec 26, 2011 5:29 pm
When the "home" key is pressed, Xlobby is minimized. Is there a way to disable this "home" key functionality?
The reason I am looking to disable this action is that I use another program (Powerhome in concert with Synergy) to "sendkeys" to my CCTV system (Geovision). One of the keys I need to send is the "Home" key.
However, this also has the unintended effect of minimizing Xlobby. It would be nice if there was a check box in the Alt-F2 setup area to toggle this hot-key like "Home" minimization functionality.
smarty
Re: "Home" Key - How to Disable Xlobby minimization???
Postby smarty on Mon Dec 26, 2011 6:16 pm
Found it!
Kiosk Mode under the options area disables the "home" key.
Yeah!!!!
smarty
