by Marbles_00 on Fri Jan 12, 2007 3:27 pm
Though you shouldn't hear a hiss (unless it's part of a soundtrack), regardless if the source is connected or not. The fact that a source is not connected there could be a fault with the amp. Though it shouldn't make a differece, are the gains for that channel set too high (even if the gains were set to max, under good conditions, it should be silent if a source was not connected)?
It could be high frequency interference, which may indicate that a small filter cap is either missing, blown, or just not performing to spec (which would be very difficult to determine...which cap?). If it is only happening in one channel at least your then isolated to looking at that specific circuitry. Though very tedious without schematics, you could trace the signal path back from the terminals and inspect all the components by comparing to one of the adjacent channels.
If the hiss appears as the amp warms up, then it could indicate a cold solder joint. That would require looking over the whole solder job on the circuit board...another tedious task.
You may be better off getting in touch with etom and see if you can just replace the amp. Or, this sucks even more, just not use that channel.
Man, I feel for ya. Wish I could be more helpful. Times like this I'd would much rather see a puff of smoke and that great odour of electronics burning smell...then at least the troubleshooting is easy...just look for the blown up part.
