Error Message
Error Message
Postby dhageremtp on Tue Feb 13, 2007 5:43 pm
can someone tell me why I get this error message when attempting to import a DVD (I am new to using this, so I dont know if it is something simple that I have overlooked):
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference not set to an instance of an object.
Details:
System.NullReferenceException: Object reference not set to an instance of an object.
at xlobby2.Setup.button22_Click(Object sender, EventArgs e)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
xlobby2
Assembly Version: 1.0.2403.37773
Win32 Version: 1.0.2403.37773
CodeBase: file:///C:/Program%20Files/xlobby/xlobby2.exe
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
XPluginSDK
Assembly Version: 1.0.2378.27802
Win32 Version: 1.0.2378.27802
CodeBase: file:///C:/Program%20Files/xlobby/XPluginSDK.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
XWeather
Assembly Version: 1.0.2387.38391
Win32 Version: 1.0.2387.38391
CodeBase: file:///C:/Program%20Files/xlobby/plugins/xweather/XWeather.dll
Interop.Shell32
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/xlobby/Interop.Shell32.DLL
CustomMarshalers
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Interop.ActiveHomeScriptLib
CodeBase: file:///C:/Program%20Files/xlobby/Interop.ActiveHomeScriptLib.DLL
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
enabled.
For example:
<configuration>
</configuration>
dhageremtp
