Hello Baddabing,
I'm using this skin on a Viewsonic Airpanel as a Xlobby client, and I'm using the "resolution" variable to set the image to 640x480 in the server.txt file so that the page will update quicker on my Airpanel. it seems the image does not shrink down at all. When I load Xlobby on the HTPC server and tell it open at 640x480 it works fine so is it some quirk in Xlobby or maybe this variable does work or you screens can't be shrunk in
client side mode.
Below is the description of the resolution variable.
resolution:
the resolution you wish to use, should be set to "auto" unless speed becomes an issue. If your having speed issues try setting a lower resolution while keeping the aspect ratio the same. So if your client is running at 800x600 you could try 640x480 or 320x240 because they all have the same aspect ratio.
