embedded application
Got an idea, post it here
Postby katsumoto on Sun Feb 13, 2005 11:15 pm
Could it be possible to have an event like "OS>execute file" but to embed the application in Xlobby like you do with the webbrowser and not to have it in a separate window?
for example: to have an excell spreadsheet in a browserlike rectangle
(sorry for the boring example)
Maybe this is possible and I just don't know how to do it!
katsumoto
Postby dalanik on Mon Feb 14, 2005 11:24 am
Yeah, if that was possible, we could just have windows media player embedded....
Postby katsumoto on Mon Feb 14, 2005 7:42 pm
So, I suspect it isn't possible yet?!
You could use Windows Mediaplayer but also any custom application you want.
As long as you don't see those nasty windows tool bars! (ugly little things)
Just imagine the possibility's!
katsumoto
Postby katsumoto on Wed Feb 16, 2005 10:35 am
is this someting that could interest other people?
Glad to hear some remarks if this would be possible.
katsumoto
Postby stevenhanna6 on Wed Feb 16, 2005 8:27 pm
I've seen it done with zoomplayer, because you can pass location and size to it when you launch it. I cant remember what skin it was in though.
I never thought of including the "windows media player" object, like I do with the webbrowser. Maybe there was a reason I didnt include it....I might look into it if other people are interested.
Postby katsumoto on Wed Feb 16, 2005 8:34 pm
I did'nt see it explicit as a way to include windows media player.
But for any application, so let's say an excell or powerpoint viewer.
I would like to use Xlobby as a tool for navigation in professional presentations. So I should be able to view other applications in the same way as you do with the webbrowser.
Could be just a new application for Xlobby.
katsumoto
Postby stevenhanna6 on Wed Feb 16, 2005 8:41 pm
I wish I could do that for any application, but every app is different. The only ones that will do what you want right now, are those that have command lines parameters...so you can launch them to a specific location and remove those bars.
The problem is some apps have that stuff hardcoded and its impossible to change the way they look.
Postby katsumoto on Wed Feb 16, 2005 8:48 pm
So what would be the way to loose the bars on the explorer.
(the vertical ones)
katsumoto
Postby badubo on Wed Feb 16, 2005 9:33 pm
I already wrote a plugin for this purpose :
http://users.skynet.be/badubo/test/XMoveWindow.dll
- put it in the plugins directory
first, find the window class name of the application you want to embed (using girder target tools or spy++). let's say you find ClassName
- create a text zone in the screen (the screen is ScreenName.xml)
- set as ID : ScreenName_ClassName
- set as Text :plugin>XMoveWindow>ClassName
Then start the application normally throught a os/execute
badubo
Postby katsumoto on Wed Feb 16, 2005 9:47 pm
looks great
but help me on the windows class name?
an example?
katsumoto
Postby badubo on Wed Feb 16, 2005 10:05 pm
didn't saw you were belgian :wink:
French or Dutch ?
I have a little documentation in french. Never had really the time to translate it
concerning the class name,
get systree++
http://members.brabant.chello.nl/~h.vanoosterhoutbos/
install it and start it
start your app
go on the left part of the start button and click the red box
- in the tree select the application you want to embed
- find the window (use right click to highlight it to verify)
you get something like :
Window: 00090466 "skynet - Microsoft Outlook" rctrl_renwnd32
the class name is rctrl_renwnd32 (the word after the one in "")
badubo
Postby katsumoto on Thu Feb 17, 2005 2:28 pm
I'm from Gent.
So it's dutch, but I have no problem with french.
If I can help you with any translation, no problem.
:D
katsumoto
Postby dgemily on Thu Feb 17, 2005 2:36 pm
katsumoto wrote:If I can help you with any translation, no problem.
:D
yep, if you can, it should be nice :wink:
when you have a time, just tell it to me and I will send to you what we need to translate.
later
dgemily
Postby badubo on Thu Feb 17, 2005 2:40 pm
So you can take it there :
http://users.skynet.be/badubo/test/XMoveWindow.doc
You can also take a look on the french forum
http://forums.studio-biorythm.com/
badubo
Postby katsumoto on Thu Feb 17, 2005 2:48 pm
I'll look in to it!
:wink:
katsumoto
