RS-232 with a USB Dongle...
Postby sdumas on Tue Jul 29, 2008 6:53 pm
Hi Everyone,
I am trying to pass RS-232 commands via a RS-232 USB dongle fron Aten. Xlobby does not seem to find the com port associated to it. (latest release - not freelobby)
I have no problems passing commands through a real COM1 port. This dongle assigns COM3 to it. I can talk to COM3 via Hyperterminal but not via Xlobby.
Command is as follow:
COM3:9600:none:8:one
!1PWR01\r
(This turns Power On on my Integra DTC9.8 )
This works perfectly with a "real" COM1 port; but via the USB dongle... nothing happens (like I said before it works also with Hyperterminal)
Any ideas?
By the way this is on VIsta 32 Ultimate - drivers are properly installed since I am talking to it via Hyperterminal
sdumas
Re: RS-232 with a USB Dongle...
Postby vaporhat on Tue Jul 29, 2008 7:51 pm
Using a recent version of V2 I was able to send communication to a COM3 port using XL, however it was a direct rs-232 port (PCI card) and not a USB.
Strange issue. Sorry I could not be more help to you.
Postby Jay on Tue Jul 29, 2008 8:58 pm
Sdumas. Was it working in a previous version?
Postby sdumas on Tue Jul 29, 2008 9:18 pm
I did not try a previous version. I think anyway that the rs-232 fonctionnality is fairly recent.
sdumas
Postby Jay on Tue Jul 29, 2008 11:17 pm
Some USB>Serial converters are not fully RS-232 compatible and will only send and not receive. You should check for a full rs-232c handshack.
Postby wesblack on Wed Jul 30, 2008 4:12 am
If you can send the command in Hyperterminal then xLobby should be able to do the same. Are you using send string, not send bytes correct. We have a USB to RS232 adapter and it works fine with xLobby, Calrad part no. 72-UC-320.
Calrad 72-UC-320.jpg (3.64 KiB) Viewed 5044 times
Postby sdumas on Sat Aug 02, 2008 8:13 pm
I got a new RS232 card to add two new ports on my machines - this worked.
I can now control my Integra DTC9.8, my Barco projector and my X-10 lights! woo hoo!
Thanks for your support anyway!
sdumas
