hazmatte wrote:I have a T-Mobile Dash running Windows Mobile 5.0 Smartphone at 320x240 landscape resolution and was wondering if anyone had tried to run a thin client over Wifi this way (or on the Motorola Q for that matter)? Is it possible, are there any tips to get it working, and what skin works best?
it should works....
it work on my smartphone using Windows Mobile 5.0...
for skin, I don't think there is a skin with ppc screens using 320x240 landscape resolution.... so you need to adapt some screens....
hazmatte wrote:Thanks again for the pointer, I will check out the skinning guide. Just for a starting point, which skin is that in your screenshot, maybe I'll start tweaking that one for landscape?
-m
tomprout wrote:Dgemily,
How does it works with your smartphone ?
Is it fast enough ? .
What about the battery life when using xlobby client on your smartphone with WIFI enabled ?
