I need a little help or direction with trying to figure out how to have Xlobby completely shutdown the pc when I click on the *shut down* button with the Heavy Metal widescreen skin Exit page /shutdown button.
I'm using windows 2000 pro for my OS
To try to make it easy on myself I dwnlded a little freeware program called *shutdown PC* which is found here
http://www.budja.com/shutdown/
I installed and made the new shortcut on my desktop and added to the command line so that when I click on the desktop Icon it shutsdown the pc.
...Works great when clicking on the icon from the desktop
I then went into Xlobby brought up the setup menu added a new group/event/OS/execute file and filled it in directing it to the shutdown.exe on my desktop....tested it.
The little dos screen appears for a sec from the shutdown exe. which I think shows me that the shutdown program was activated
Now for some reason it wont shut down Xlobby and then the PC.....
I still have to click on the exit button which brings me to desktop and then shutdown the pc...
Is it possible to shutdown the pc with Xlobby??
Thnks Rick
