Hello Steven,
First of all thanks for enabling the use of arguments in plugin commands it will help me a lot
I have now a little question, I want to send a command to a plugin containing variables of xlobby (here, the channel and start time of the selected EPG item)
I tried : %epg>channel% %epg>time>%
But I receive them "as is" in the plugin, there are not expanded.
using them in a screen shows the requested information
How can I format these variables?
Also, do you have the list of variables we can reach ?
Note : I may be seen a little bug, it seems that epg variables are not accessibles if xlobby just generated the .dat (it works the second time we start xlobby
Thanks for all
