This forum is for questions
Is your vids played with TT if you start them direct from hard drive?
If not then press f2 from inside xlobby.
Press "File Types" and ad the extention (mpeg or what extention you like) to the program you like to start your vids.
Don´t forget to check the "enabled"-box
Close xlobby setup
Go to home video screen
Ok from home video screen you have to make a file browser.
Press "pause/break"key (opens skin editor)
Press "Screen"
In "Folder Browser" add your path to your vids (D:\Myvids or what ever)
Press add
Mark your new file browser and then scale and place it in right place on the screen.
Under "Item" - "Category" you can change columns,rows and so on, to your likeings.
Under "Items" - "Display" you can change the fonts to your likeings.
Close skin editor
Now when you press on a vid your favorite player should start...
If you like a example you could go to filebrowser in the skin. ( main menu - settings - help - files)
you could also make a new database and play them from movie screen but that is a different story...
I hope this helps
Rika
