generate folder "collage" images?
Postby S Pittaway on Tue Aug 29, 2006 9:10 am
Steve added the "folder back" entry last week hand i have finally been able to use Artist>Album>Detail based views...
But i noticed that the image used in the artist view is just the first album?
IE, Queen have done loads of albums, but for some reason it shows greatest hits volume I has the picture.
It would look a loy nicer if it used a collage of all of the photos in the subdirectorys.
Id there an easy way of generating these images - i dont really want to spend ages doing it by hand?
i dont supoose anyone has knocked a plugin up to do something like it?
Falling that i dont suppose anyone has any code to do this sort of thing and i could add it to a plugin?
Cheers, Sean.
