http://www.xlobby.com/images/xlogo.jpg
this should be showing up under the plugins page
Naylia wrote:now we just need people to update their initial posts
and guys i noticed some people added the http://www....but you need to follow steven's first post for the format for the beginning of your first post becasue that's what the plugin page will use
ComputerTimeCO wrote:Naylia wrote:now we just need people to update their initial posts
Hi Naylia,
I guess you mean me since its the only one I see with www at the end. I followed Steven's format but it would not show up in the Plugin's section so I remove it. I just forgot to remove the www from the subject area. I'll give it another try and leave it with the formating in place. Maybe Steven can fix when he has time if possible.
Regards,
Carm.
