dalanik wrote:I have NetTransport installed and correctly setup in config file. Any ideas
using the graphical application, are you sure the path pointing to NetTransport.exe is the good one too...( case: "Repertoire d'installation de Net Transport") should be ok if you did it using the cong.ini file but it just to be sure.....
can you tell us which version of nettransport do you use ?
later
