by Kasperl on Sat Feb 19, 2005 7:36 pm
Now, I'm a bigger n00b then you are, but generally a TV card ought to be installed by just plugging it in the PCI slot, installing the software, plugging the cable in the back (the one you'd normally put in your TV), and RTFM'ng the stuff that came with the card.
As for running TV over the LAN, I'll let someone else comment on that.
