Use XANT to list movies by date added...
Postby Marbles_00 on Wed May 05, 2010 4:56 pm
I may be doing a new skin, and I've been experimenting listing the XANT movie database by date added. What I would like is to list from most recent movies added to older. What I'm getting though is the opposite, where older entry movies are listed first then the new ones. Anyone know of a way to change this? I'm stewing some thoughts, but so far coming up short.
Re: Use XANT to list movies by date added...
Postby samsonlov on Wed May 05, 2010 5:02 pm
Did you try using a "-1" before the sort variable?
Just a thought.
Postby scottw on Tue May 11, 2010 4:06 pm
Yeah I do a "Set Sort Order" and use "-1:number"
Postby Marbles_00 on Tue May 11, 2010 10:45 pm
Scott,
That was what I needed. Thanks for it.
How are ya doing anyways...haven't heard from ya for a long while?
Send me a PM.
