Naylia wrote:Hey guys! Having a problem...seems that any commands I put in the defualt column will always execute even if I put a command on the same line for a particular screen ... any ideas?
badubo wrote:Hey guys! Having a problem...seems that any commands I put in the defualt column will always execute even if I put a command on the same line for a particular screen ... any ideas?
Did it work before? Do you use the last version of xlobby?
Can you export the .ini ?
