Weather plug-in help for a UK user
Postby lscolman on Mon Dec 20, 2004 5:21 pm
Hi,
I'm using the visual.v049 skin, and it runs an absolute treat on my simpad in 800x600 mode.
Has anyone a reasonable guide to how to get the weather plug-in working for UK and Local Weather? Some pointers would really help. I've tried reading quite a few threads, but must admit to getting a bit lost?
Any help appreciated.
Cheers, Lee
lscolman
Postby edgley on Mon Dec 20, 2004 10:39 pm
Hi Lee,
Does it use the xoapweather plugin?
edgley
Postby lscolman on Wed Dec 22, 2004 9:55 am
Hi,
I'm not too sure about which plugin it uses, if any. I've managed to get it working I think.
I've located the jpg source images from http://www.weather.co.uk, and replaced the XML JPG source file from American maps to UK ones.
I then press the update button on the skin, and hey presto.
Is there a better (more automated) plug in that works better than this?
Cheers, Lee
lscolman
