freebits,
I think I may have a solution, but I need you to do a little test for me. Copy this text to a notepad and save it as "program.tvpi" (NOT tvvi)
EDIT: I had to send you an e-mail with the text, it would not display correctly here for some reason
Open this file with Titan app (MyHD doesn't have to run, but you should have "Virtual Channel Mode" enabled). A window should popup and in the "Active Channel" drop-down find your channel 7-1 and click OK. Now, there are 2 optioins (I hope
1. You'll see message that "TV Mode is not compatible with the selected channel" in that case cancel everything, open above file again and change tv-mode from "digital_cable" to just "cable" (or maybe "digital", but try cable first) and try the whole thing again.
2. You'll see message asking if "You want to update the virtual channel number of the selected channel? ....." Click NO. After that you should see message that you've added your recording.
Let me know...
