This might not be of any use to most people.. but anyway, I needed it so thought I'd share.
http://www.xlobby.com/files/defrag/xOfflineExtender.zip
What does it do? Well, each media player can only have ONE offline event. This is probably fine for 95% of users, but that doesn't include me!!! I have one location for boxed offline dvds and an indexed trunk for non-boxed dvd's. So I needed a way for the movies to point to one offline overlay and the tv episodes to another (which had the index on it).
The plugin looks at what screen you are on and opens an overlay with the name of the current screen + "_offline". So in my XPro skin I have the movies_offline and series_offline, these are now selected automatically.
So how do you use it? Well in the offline event on the file types tab in setup, just point the offline event to an event pointing to this plugin. There is only one command!!!!
If you have no idea what I'm talking about, or don't know what offline events are, then this isn't for you
Enjoy
