xmovewindow
xmovewindow
Postby epitaph on Thu May 18, 2006 8:03 am
i cant seem to get xmovewindow set up properly.. i looked at both french and english and still couldnt figure it out, and i have the latest xmoviewindow
I just want it to play trailers in small window via zoomplayer
I did the following
Placed the xmovewindow.dll into the plugins folder
Created a screen called movietrailer
Created a TextBox with the Text: plugin>XMoveWindow>TMainForm
Added the ID: movietrailer_TMainForm
i have a category and a filter that filters my movie trailers down by display name leaving only the right trailer(s) remaining and when i make my selection i want it to load up zoomplayer and play my trailer in a small window.
epitaph
Postby epitaph on Thu May 18, 2006 11:49 pm
epitaph
Postby dgemily on Fri May 19, 2006 1:07 pm
sorry can't help you :? I'm not using zplayer....
but this should work using:
did you try with an other skin using zplayer+xmovewindow ?
I think MediaX from QTips use it .... : http://www.xlobby.com/forum/viewtopic.php?t=3395
dgemily
Postby epitaph on Fri May 19, 2006 3:45 pm
thanks, ill check it out.
epitaph
Postby P3rv3rt B3ar on Fri Sep 01, 2006 11:34 pm
I would like to embed dshow video renderer (either VMR or older kind) directly to xlobby using xmovewindow... but no success so far... Any ideas?
I believe window class is VideoRenderer and Caption is ActiveMovie Player but i had no luck using either one :cry:
Anybody managed to do this?
