So far its coming out really good, and is suuuuuuper easy to get around with a remote. I designed it to be easily navigated/operated with just up/down/left/right/enter commands of a remote. Play/stop/etc buttons of course are very useful to for ease of use.
You will notice how things are aligned in columns that you can scroll up/down through, and you can jump to the next column with left or right. I've been trying to keep that theme as much as possible.
Here's some screenshots, please give as much feedback/suggestions as you want.
Music:
I changed the switch buttons for play, queue, open to radio like checkboxes, this seems much more intuitive to me than the boxes I used to have.
Album Tracks:
Note the icons to the right of the tracks that indicate if the track is currently playing (play icon), currently queued in the playlist (checkmark), or not in playlist (X)
Playlists:
Now Playing:
Note back on the music and playlist pages, how there is a "fullscreen" tab towards the bottom that basically makes the bottom "now playing" section fullscreen.
Search Music:
Advanced Options:
Jump To:
This is a new feature I just added that brings up an overlay with a scrollable alphabet DB, where you bring this up, scroll to a letter, select it and it will automatically take to the first artist that starts with that letter. Works out real handy.
Quick Menu:
If you notice on most every screen the upper left hand corner tells you what section of xlobby you are in. If you click it, it brings up a quick shorcut list of other sections. I have not worked on the appearance of this at all, so it will change before I release it, this is just a simple layout for now.
Main Menu:
Pictures:
All of the other sections I'm still working on, and will post them when they are getting closer to ready. I have been working on movies and ppc screens a lot too, so those will be around soon.
Again please give any feedback/suggestions to help improve this skin.
Thanks!
