Problem with shrunken movie cover art from DVD Profiler
Postby Rizlaw on Mon Jul 24, 2006 6:14 pm
I am not certain if this an XL problem or DVD Profiler 2.4 problem.
DVD Profiler does not list the movie "The Puppet Masters" in its database, so I manually created the entry for this movie in Profiler and added my own cover art. I also made certain that the check box "Stretch to Fit" in Profiler was checked (not sure what that does, but it seems to be always checked by default). I then exported the modified "Collection.xml" file so that XL would use it for the cover art and info for the newly added movie.
This normally works fine when Profiler has ALL the data (cover art and other movie data). In XL the 8 individual rectangular boxes that display the cover art show the cover art so that it completely fills all the rectangular boxes. HOWEVER, in the instance I described above, the cover art does NOT fill the rectangular box 100%, it's more like 60%.
Does anyone know if this is an XL issue or Profiler issue; and, most importantly how it can be corrected? Thanks, in advance, for any help.
Rizlaw
