Thank you for your responses.
Aaron:
If I can make some suggestions to make it more touchscreen and TV friendly
All round buttons "zoom out" in colour on enter-state, You can look at the web-home button
here to see what i mean. That make use of touchscreens to lose that effect. I use mouse or remote for this skin.
(Edit: You could change enter.png´s to down.png´s that way when you press a touchscreen the button will pop out in colour)
1) If you can make the 'home' page buttons a bit larger. Thus moving the XLobby 'oval' more towad the center to allow for the larger buttons.
Larger home button, no problem. Move the "oval", i vant the space for a calendar and info on the right side but i can uppload all the layerd png:s so anybodey how wants can tweak this skin to ther own choice.
2) On the picture viewer... can you make the overlay larger to fill up "most" of the screen? This would make it nicer to view.
As this skin use jowaldos skin as base the picture viewer are the same as in jowaldos skin. If you mean
this its the webcams
hjackson:
Is there an EASY way for us in the masses to change the color or hue of your skin or would that require an entire overhall (I do a lot of skin tweaking but have never tried to change the colour...)?
Sorry, you have no easy way to change the colour but as you are one of the 100$ donator when steven had problems with his server, i will tweak this skin in any colour you want for you. About the button sizes, i´l see what i can do
Rika
