Schedule and record with ALOT of cards www
Fixed.new version out
Postby lar282 on Mon May 02, 2005 7:33 am
JUST when u wrote that I tried this....and it worked.NEW zip file IS uploaded to the web.
DateTimeFormatInfo english = DateTimeFormatInfo.InvariantInfo;
string startdayofweek=epg.GetStartTime().ToString ("ddd", english); // This is non language dependent
http://hem1.passagen.se/lar282/xschedule/screenshots\
PS:JLF can u mail me at mailto:lasse10@telia.com need to ask u something:DS
Postby JLF on Thu May 05, 2005 7:26 pm
Weekly and Daily work great for scheduling. Is there a way to give them a unique title so they do not overwrite the previous on?
JLF
JLF
Postby lar282 on Thu May 05, 2005 8:25 pm
Dont know really. the schedule is the same so I guess its up to gbrecord!
I think I can use the %date% in the recording file name.that should do it
I'll think about it and will get back to.
regarding the png files..I tried too but it wont crash for me without the png files u mentiones. wierd. I did include the png files in the zip and uploaded the new zip now.
EDIT:Though about it and uploaded a new DLL its not in the zip but by itself.try it say what u think.it will replace %date% on the recording filename.
Postby lar282 on Sun May 08, 2005 6:15 pm
New verison that will put the DATE in the filename of the recording. This will help if one records weekly or daily so the file will not get overwritten.
%date% works for me cause it returns 2005-05-09, but I am unsure what happens if the system locale puts a semicolon in there instead! Wonder what English system locale puts there?
Postby JLF on Mon May 09, 2005 7:59 pm
I think I have another win2k vs. XP problem. The global %date% variable gives me “Mon 05-09-2005” in the command line. No matter what regional setting I use, I can not get rid of the “Mon “ (I even tried Netherlands). The space between the Mon and 05-09-2005 causes an unknown argument error. If anyone has any ideas on how to eliminate the day of the week in the Date global variables in win 2000, please let me know, I can not find any info on the web.
JLF
JLF
Postby lar282 on Tue May 10, 2005 6:45 am
U can try to do this...
control panel-Regional Language setting--press customize and select whats on the picture below.
http://hem.passagen.se/lar282/xschedule/
PS:I will contact the author of GBRecord and see if I can get the source code or if hi wants to add ### feature:DS
Postby lar282 on Tue May 10, 2005 7:30 am
got a reply from the author
-"I will try to add this feature. Unfortunately I'm very busy changing jobs at the moment, but I will try to do this within the next couple of weeks."
Postby lar282 on Tue May 10, 2005 8:50 am
Man, things move on today.
NEW version that creates a uniqie filename. The author of GBRecord added ### feature and my plugin now requires 9.2 of GbRecord.
I included the new GbRecord (v9.2) in the zip file.See first post for link.
Postby sub3 on Tue May 10, 2005 5:38 pm
You do not have permission to redistribute GBRecord. Please remove it from your zip file.
User requiring GBRecord can download it for free directly from my site http://www.gbpvr.com/GBRecord92.zip
sub3
Postby JLF on Tue May 10, 2005 10:19 pm
My initial testing would indicate GREAT JOB. I will use it for a few days and let you know if I have any problems. Thanks for all the hard work It is a great plugin for recording TV.
JLF
JLF
Postby lar282 on Wed May 11, 2005 5:54 am
Hi SUB
Truly sorry about the zip file. I honestly thought it was ok. I have removed it and once again thanks for a great application.
EPG goto current time slot in EPG
Postby lar282 on Wed May 18, 2005 8:39 am
I just uploaded a new version that can go to current time in EPG.
Pass the xml filename to the plugin command for it to work. Read the log if its not working nd post the error mess here.
regards
Postby badubo on Wed May 18, 2005 8:53 am
did you use the above trick?
badubo
Postby lar282 on Wed May 18, 2005 9:13 am
found a bug. have to fix it
EDIT:Fixed. The time of the zip should be 12:22 then its the fixed one.:
no I didn't use the above trick. That wont work. I used a really ugly,ugly solution but it works!(at least for me)
the trick is to use EPG:Refresh:xxxxx
Postby QTips on Wed May 18, 2005 6:57 pm
Startet lurking around with this plugin and thought using it with myTHEATRE for DVB records and viewing but I constantly getting "Failed to create schedule" error message
is it beacause I'm using a network domain and not Workgroup ?
[SCHEDULE_CONFIG]
USERID=system
USERPASSWORD=
I put in my userid and password there with no luck
QTips
