I assume you are refering to show and hide feature. If you want an image to show on rollover, you must give the image an ID on the general tab. Then select the hidden checkbox. On the advanced tab, the images with ID's will be listed. Select the button you want to associate this hidden image with and then select the image from the list.
Hi,
Yes, it is the show and hide feature associated with the buttons on the menu page.
Where do I find the general tab - in set up under general tab I only have winamp zones; trailer paths; Daemon tools.
How do I add another image and text.
Sorry to be a pain but I really think Xlobby is superb and lends itself 100% to personal customizing - although some things are way above my head.
