Force Xlobby to generate a new collage??
Postby fizzasist on Sat Feb 24, 2007 2:42 am
Is there a way to force Xlobby to create a new PNG file for the menu screens? The collage-movies.png got generated with a picture that is not from one of my movies for some reason and I don't want it in there but I can't seem to get it to create a new one.....I figured if I removed it, then it would re-create one but the screen just comesup with a big yellow box.....
fizzasist
Postby m_ski on Mon Feb 26, 2007 12:46 pm
You need to refresh the database to get it to generate a new image. Also, the collage-movies.png file must already exist before you do the refresh. Put it back or just create a new file with the name collage-movies.png in the buttons folder of your skin, then do a refresh.
m_ski
Thank you!
Postby fizzasist on Mon Feb 26, 2007 4:11 pm
I thought I had tried that already but I must have removed the png file first because this time it worked...thanks for the help!
fizzasist
