 by jji666 on Tue Feb 05, 2008 5:28 pm
			I've been able to have the zoomplayer plugin show up under the plugins list, and have been able to load zoomplayer using the events provided in the sample skin by using the "test" button on the events configuration page.  "Clear playlist" also appears to work.  But I cannot figure out how to get it to either play a video or add a video to the playlist.  These commands don't seem to work.  Is the problem that I am using Zoomplayer Pro?
I've tried various permutations of syntax, like creating an event that changes the mode to addmode, and then using the command to add a file, etc., but I cannot get this to work.  Can anyone give me an example of a syntax that works to get the current selected category item into the zoomplayer playlist from a button on the overlay that opens when you click on the item in the database?  I have the button there, and the event programmed, but I cannot get it to work.  With this I will be able to have a bunch of people at a party all contribute music they want into the playlist from various touch panel controls, a killer app, but I can't get it to work!
Thanks!
JJI666
