Lost my EPG
Lost my EPG
Postby homepc on Sat Apr 28, 2007 3:44 am
I was cleaning up some files in XL and think I must have deleted some files that I needed. Now when XL starts, I dont even see the "Building Guide: xmltv" text. When I get into XL, and goto the TV screen, there is no epg. When I go into edit mode and try and add an epg, there isn't one to select.
Where should the xmltv.xml file be? In what folder? and what other files do I need to be with it?
Ry
homepc
Postby homepc on Sun Apr 29, 2007 1:24 am
Nevermind......found my problem. thanks
homepc
