Xlobby & Windows 7
Xlobby & Windows 7
Postby lar282 on Thu Aug 13, 2009 12:45 pm
Hi all
Just installed win7 RTM on my big htpc and all seems to work fine exept...
The darn taskbar is flashing everytime deamon tools mounts a iso/img. Also it flashes whenever zoomplayer closes and returns to Xlobby. I already tried to remove the taskbar with a small app but no joy. Anyone seen this behaviour?
Re: Xlobby & Windows 7
Postby lpg on Sat Aug 15, 2009 5:41 pm
I had driver issues with my matrix orbital and griffin devices so I had to abandon the software. Does the task bar clear out when you run everything outside of xlobby?
Postby lar282 on Sun Aug 16, 2009 8:00 am
What do u mean by clear out?
Postby lpg on Sun Aug 16, 2009 6:01 pm
Stop Flashing
Postby Bill Lott on Sun Aug 16, 2009 10:06 pm
very cool. Now you got me thinking about the skin I'm using...
Bill Lott
Postby lar282 on Mon Aug 17, 2009 6:35 am
ha ha ha.
yes, it stops
it just gets focus for 1-2 sec then focos returns to the correct application. Annoying as hell
Postby lpg on Thu Aug 20, 2009 2:16 am
I switched from daemon to virtual clonedrive from Slysoft it is freeware. You may want to try this. I wrote a support doc the the freeware section to show how to set it up. It sounds like Daemon is causing the problem. The other issue may be that Win 7 is not quite complete and may have an issue with what Daemon is doing. Just guessing.
