rbziggy wrote:Last year, I posted various messages on this thread about using a multiple output stacker plugin in Winamp to route one winamp instance to several soundcards. (e.g. creating an 'All Downstairs' zone in winamp that would toute to not one but three soundcard outputs.)
This all worked very well for me with no syncing/drift issues and I've been using it since.
However there was one flaw that made it less desirable for many. When you started xl/winamp, each of the outputs in that instance of winamp ended pointing to the same soundcard. So you had to go into the winamp instance and reset the outputs to the individual soundcard. Bit of a pain!
Well, I've just upgraded to winamp 5.31 this morning (it has support for FLAC formats now) and... The problem outlined above has disappeared. Somehow, they have changed something in the config of Winamp that means your config for each output is not lost.
So, I think this is a really good solution now for the multi-zone issue. Though I'd share this good news!
OMG, this is great!!!!!
I have just revisited multizone audio since I bought one of the 6 channel amps in this forum. I spent 2 days trying to find where those registry or INI file entries could be changed. I figured maybe something could be written to set the right outputs on startup of XL.
So you just upgraded Winamp and used the same stacker plugin right, I am going to try right now.
THANKS!!!!!!
