I have Win XP Pro, I had Xlobby, ZP, and Winamp running perfectly fine with the heavey metal skin. I bought a win pvr 150 and downloaded the ctpvr application and installed both of them.
Now, whenever I go to run xlobby it freezes on the splash page at "Loading:setup." I ctrl-alt-delete and go to shut down the Xsplash application and I get a Microsoft .NET Framework error box that says this:
An unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will be shut down immediately.
Object reference not set to an instance of an object.
If I push continue nothing happens, the screen just sits on the splash page.
Can someone help me fix this problem? I have tried reinstalling the .NET stuff but that didn't work.
BGB
