byellin wrote:minhi,
Yes. TT does play.
not sure if this will be ok with you, but this is the workaround that worked for me. it's simpler because i'm not messing around with the file types.
i think your problem is because you cannot pass %title% in the file types section. to do it that way, i think you have to add a new playlist event, and play playlist event. that's my guess, i haven't done it that way. hopefully someone else can explain how to do it that way, too complicated for me, i need to keep it simple.
my workaround is to create a new event playdiskmovie, in that i have just one item, os->executefile.
File=C:\Program Files\Zoom Player\zplayer.exe
Arguments="d:\movies\%movies>title%\video_ts\VIDEO_TS.IFO"
(obviously modify this for theatertek)
then i go to the skin editor, (break button) and bind this event to the "Play" button in the movie view. This is kind of a cheat because i bypass the offline/online check (which i'm trying to fix myself--i can't figure out where it checks), but it will get you moving again.
