Hi,
I have been playing with XLobby for a little while now and have customised the "BONG" skin a little to suit my needs.
One thing that I just can't get working is the event "Zone Set", I have basically setup two zones "Lounge" & "Deck" of which i can get music playing through two different instances of Winamp. This all works well...
However i want to setup buttons on the main menu and the PPC Menu screen that you click on and go straight into controlling that particular zone. Zone Set should do this? However no matter what i try, Zone Set: Lounge OR 0 OR 1 it just doesn't work. However I can use "Zone Next" and it will toggle between the zones.
I have the two instances of Winamp in the following locations,
C:\program files\audiozones\Lounge
C:\program files\audiozones\Deck
(Note: Not sure whether it is case sensitive but I have tried a number of options)
Can someone please help me out with this one....
Thanks in advance.
Chad
