i am tring to do the same set up as your self using a elo touch screen
could you please tell me which graphics card your using ( i want to run it on Yamaha dlp projactor at 720p using a dvi ) and your the config please.
Is it possible to control and see xlobby only on the elo and the movie on the projector screen and when no movie showing you just see the TT logo /or a logo of my choice
many thanks
