minimum hardware requirements for a Xlobby server?
Postby oreoboy13 on Tue Mar 16, 2004 11:57 pm
Looking to put the cheapest possible pc together to act as a 24/7 xlobby multizone music server.
Anyone know the minimum hardware requirements needed to run xlobby without any lag?
oreoboy13
Postby rika on Mon Apr 05, 2004 7:27 am
bump
rika
Postby Arthur on Mon Apr 05, 2004 12:58 pm
Minimum requirements, I really don't know for sure but:
- It should be able to run .net (maybe MS has some min req.)
I would advice you to use a liquid bearing harddisk as it will be spinning all th time.
Arthur
Arthur
Postby jowaldo on Mon Apr 05, 2004 5:19 pm
Just for playing music anything over a 1ghz machine with 256mb on XP should have zero lag... probably could get by with much much less though, the only thing I could see being lagged is changing screens if you were on a slower machine. Audio should run fine on a p3 350 even
