Main screen controlling buttons with keyboard
Postby lar282 on Fri Apr 16, 2004 12:31 pm
Wierd thing. When I press the UP key on the keyboard it goes up to the next button, up again works but the third up goes to the wrong button. I have 6 button in a row. Like this
Musik
dvd
Filmer
Fotografier
Titta på TV
Internet
When I start from Internet and go UP with the keyboard it works to Filmer, then it jumps back to Fotografier?????
Where is this controlled and how????
Postby milanp on Fri Apr 16, 2004 12:46 pm
Just make more space between buttons or decrease the size of the buttons.
It will surely fix your problem.
You have overlapping buttons and Xlobby is confused about that.
Hope this helped you.
milanp
Postby lar282 on Fri Apr 16, 2004 2:11 pm
thanks for the tips.I'll try tonite and post reply.
I have alot of space in between the buttons but they are big so maybe it's the size
Postby Twit on Fri Apr 16, 2004 6:14 pm
Watch out - because if you use png's or gif's there can be alot of transparent space around your buttons.
In other words the buttons themselves do not look like they overlap but if you click them individually in the skin editor it outlines the whole button which can overlap - transparent bits included.
Twit
Postby lar282 on Sat Apr 17, 2004 6:35 am
It worked. Thank you so much
