Will this Audio card work for multi-zone? - good buy too!
Postby Aaron on Mon Apr 03, 2006 8:35 pm
BestBuy has the X-Fi Xtreme Music for only 97 after a 33 instant saving from 130.
Link: http://www.bestbuy.com/site/olspage.jsp?skuId=7293813&type=product&id=1118841152655
Aaron
Postby Naylia on Tue Apr 04, 2006 12:23 am
Are you looking to use the analog outputs or the digital output?
Naylia
Postby Aaron on Tue Apr 04, 2006 12:45 am
analog for multi-zone
Aaron
Postby Marbles_00 on Tue Apr 04, 2006 3:12 am
If you are planning on using the KXDrivers, according to their website, that card is currently not supported. See the link for supported/unsupported cards:
http://kb.kxproject.lugosoft.com/list.html
That is not to say that one day the card will be supported by those drivers, just now right now.
Hope this was helpful.
David
Postby Aaron on Tue Apr 04, 2006 3:29 pm
I was just wondering if it would work without hacked drivers.
Aaron
Postby Naylia on Tue Apr 04, 2006 3:54 pm
Yes, it will work as a second audio card/zone. If you wanted only digital out then there are better cheaper options, but for analog out that's a good choice. I'm not sure if the card supports multiple zones in and of itself. I'll look around and see if I see anything.
Naylia
