After the bathroom photos by Bristolman I will post some photo's of my XLobby setup, which is running in the livingroom. It is really amazing how good it works (runs for days).
I don't tell people how it works, I'll just let them play and they all get the hang of it very easy (I only have to explain the home button on the top right). (Thanks Steve / Jowaldo).
As I could not get EPG running the way I wanted it, I use a webpage with channel information.
Besides XLobby & winamp I use:
- Girder 3.2 and a small proghram "sendfocus" as I had problems when I tried to set focus to a window http://home.tiscali.nl/vannoort/xlobby/sendfocus.exe
- Click-N-Type, a free program for an on screen keyboard. You can even create your own keyboard.
- gphotoshow, a nice screensaver. It mixes the photo's slightly and if I add a new folder to the photo's folder It will automatically add those foto's to its cycle
- a program to check the clock of my computer, I noticed the computer time looses about a minute by the hour when xlobby is running.
In order to prevent 2 programs creating sound at the same time I added the following:
When a page with sound is opend (music / radio / TV) a termination signal is send to the other 2 programs. I find this better then termenating the sound when you leave a page. For instance, I I listen to a CD and want to watch the whether, no need to turn of the Cd, however, if I want to switch to radio, I don't want to have to turn of the CD first.
Ok, and here are some photo's, if they don't load, just have a look at:
Things I still want to improve/ add (top of list)
- A classical music section
- Using master volume control instead of winamp volume control
Arthur
