I continued to look the way variables are handled by xlobby.
I found that
variable>nom_de_la_variable existed.
And if I specify for example:
Http://pca/base/index.php?power = "%variable>powe%r"
It works very well if I sent "
123456" in the variable "
power"
I managed it thanks to the "
save to variable" available dans les evenements "xlobby".
Now that I found this, I therefore seeks to send the information I have in "
plugin>xap-xlobby>text>tension" in a variable.
It is indeed a variable plug, but when I want to affect it with the method explained above (with "save to variable"), it affects not just one figure, but the alphanumeric string "plugin>xap-xlobby>text>tension" if I add % of the front and behind, it does not work either.
If anyone knows a way to assign to a variable xlobby a variable after a plug-in, please do not hesitate ...
