scalt wrote:Regarding the PPC thin client with VAC setup, which I also want to implement in my skin, I was thinking of using 2 different screens.
First screen, you select the Source, it then brings you to another screen or an overlay where you select the different zones. This way, you can be assured that you only have 1 source selected at a time.
Just a thought...
EDIT : An advantage of the 2 screen approach for the PPC is that screen real estate is much more limited. It would probably be way to crowded to have everything on 1 screen with a PPC
That's a good idea, may be a much better/cleaner solution than the one I posted on my post
Marbles_00 wrote:If you go to the KX Drivers website, they have a card compatibility list. Worth looking at before you purchase a Live/Audigy.
I picked up a SB0100, I think, for $5 off ebay and it works great for 3 zones and a partyzone, I think you should copyright "partyzone" Marbles.
