to view your your webcam via xlobby
1 – Download the files 3 zips for this plugin
- http://france.xlobby.com/download/A_mettre_dans_Xlobby.ZIP
To put in the repertory “Xlobby” (2DLL),
- http://france.xlobby.com/download/A_mettre_dans_Plugins.ZIP
To put in the repertory “Plugin” of xlobby (1 repertory Xcam with indide, 1 DLL and 1 INI)
- http://france.xlobby.com/download/A_mettre_dans_System32.ZIP
To put in Windows\system32 (1 DLL and 1 OCA).
2 – Register the OCX with regsvr32 command:
%SystemRoot%\system32\webcam.ocx
3 - Launch Xlobby and press F2. In “Plugin” choose Xcam and launch the configuration
In this window choose a device in the list of video detected by Windows
, press Set device and launch a test. At the right side, you will see something it‘s mean that is good, press Ok to save
There are 5 commands:
-Show
To display the window with video flow on global overlay. It’s mean that the video flow will be always on front of the active application (Xlobby, zoomplayer ...)
- Hide
To hide the window. If you want only the wecam window on 1 screen of xlobby, you must add this event in the exit event of your screen
- Start
To active, in real time the video flow
- stop
To stop the video flow (black screen)
- location
To display the window where you want, you have to write on parameter "left|top" (like 230|120).
Thanks to Ptrinchi
