problem installing xlobby
Postby fonetics on Sat Feb 19, 2005 4:01 pm
Hi,
downloaded the software. When trying to install it says:
äpplication has generated an exception that could not be handled.
proces id=0xaec(2796) thread id=0x51c (1308)
when i press "cancel" i get a popup saying my registered JIT bedugger is not available. Please check computer settings
cordbg.exe !a 0xaec
any ideas ?
thanks in advance,
fonetics
fonetics
Postby milanp on Sat Feb 19, 2005 4:21 pm
Do you have .net 1.1 runtime installed ?
Download all the files listed from
http://www.xlobby.com/Downloads/Xlobby
and install .net.
All the other files should be extracted in one folder in the same order just like on the link.
milanp
Postby fonetics on Sat Feb 19, 2005 4:24 pm
yes, i have .net (1.1) installed. but no luck.
fonetics
Postby BaddaBing on Sat Feb 19, 2005 4:27 pm
To install Xlobby correctly insure that the following files were unzipped into a directory and in this order:
1] xlobby2pre14.zip - from the Xlobby download page
2] xlobby2main.zip - from the Xlobby download page
3] xlobby2.exe - from the Xlobby download page
If your are prompted to overwrite click 'YES'
BaddaBing
Postby fonetics on Sat Feb 19, 2005 5:01 pm
thanks, that did it.
fonetics
