m_ski wrote:You can use girder to send a maximise command to xlobby. This could trap a specific keyboard shortcut that you define and then maximise xlobby whenever you press it.
In my setup when I press the menu button on my remote it maximises xlobby and returns to the main menu.
I do use Girder, but I'm not sure how you are accomplishing this.  Can you give additional detail and/or share your gml file that does this?  It's simple to assign a remote key to "HOME" to minimize XL, but "restoring" or "maximizing" it back to full screen is where I seem to be stuck.
Thanks for your reply and any additional info you can provide!
